How to Create a  new Solid from a pipe like Solid ? (to make void cut)
ChengboZhang
ChengboZhang
All family Instance  are  made by Adaptive Metrics Generic Template.
I want steal some info from the "Pipe" like    (as first picture) to create a new one (as the second picture).
Att:  The  pipe's cross section  are not all ways circles, it can makey  be  any arc and line (as the third picture)
finally I will  use the new solid to  void cut other instance( as the fourth picture)
ChengboZhang
The above is a simplified description
The following is an example in a real scenario.
Thanks in advance.
jeremytammik
Just out of curiosity:
Is you final goal to create and display insulation around the pipe?
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
Do you really mean Solid when you say Solid?
The Revit API Solid class is a non-persistent memory-only geometrical object that is not stored in the database:
https://www.revitapidocs.com/2020/7a3b5ac1-c66d-9f81-a11d-9bcd4e026295.htm
If that is what you are after, your task is easy.
Use the methods on the GeometryCreationUtilities class:
https://www.revitapidocs.com/2020/e829700d-48ff-0914-b288-5ceb93d8ee86.htm
From the pipe, you can extract the centre line as a curve and the radius.
With those, the GeometryCreationUtilities enable you to create the desired solid.
Jeremy Tammik
The Building Coder
ChengboZhang
No, My goal is to   manager  a pipe  intersect  with(or connect with)  another  pipe.
ChengboZhang
Thank you for your kind reply.
The word Solid is ambiguous in Chinese ,sorrry for my poor English.
I understand what you mean.
I have solved this problem by delete the void Form
Also Refer to this article ,it's helperfull.
https://thebuildingcoder.typepad.com/blog/2009/07/revit-form-creation-api.html
Thanks~
