Help with setting rebar layout rule
Revit 2018 API and versions prior had the following methods which were removed with the release of the 2019 API:
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsFixedNumber()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsMaximumSpacing()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsMinimumClearSpacing()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsNumberWithSpacing()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsSingle()
I have been trying to change the layout rule setting for a set of rebars without any success. Is there any replacement for the above mentioned methods that I do not know of? Could someone explain how one sets the layout rule for a given rebar element with Revit 2019 API?
I will be grateful for any assistance offered.
Sydra7
I have the same problem. Those functions are replaced to the RebarFreeFormAccessor class but I get SEHException every time if I try to use those functions.
Sydra7
So the free form rebar is just full of bugs. I think the api functions are not even tested once. I recreated the rebar as shape driven rebar then I called the
rebar.GetShapeDrivenAccessor()
 This accessor allowed me to use the
accessor.SetLayoutAsMaximumSpacing(spacingarrayLengthtruetruetrue);
function without SEHExceptions. So it is working.
Thommy_
hi @Anonymous
have a look at line ~400:
https://github.com/tt-acm/DynamoForRebar/blob/master/src/DynamoRebar/Nodes.cs
Best,
Thomas
Thomas Vogt
VDC Technology & Process Manager
Revit®, Dynamo, BIM  |  Training und Consulting in Stuttgart
E-Mail | Twitter | LinkedIn | YouTube | Facebook | Blog
