Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Help with setting rebar layout rule
3 REPLIES 3
1263 Views, 3 Replies
Revit 2018 API and versions prior had the following methods which were removed with the release of the 2019 API:
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsFixedNumber()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsMaximumSpacing()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsMinimumClearSpacing()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsNumberWithSpacing()
  • Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsSingle()
I have been trying to change the layout rule setting for a set of rebars without any success. Is there any replacement for the above mentioned methods that I do not know of? Could someone explain how one sets the layout rule for a given rebar element with Revit 2019 API?
I will be grateful for any assistance offered.
3 REPLIES 3
Sydra7
I have the same problem. Those functions are replaced to the RebarFreeFormAccessor class but I get SEHException every time if I try to use those functions.
Sydra7
So the free form rebar is just full of bugs. I think the api functions are not even tested once. I recreated the rebar as shape driven rebar then I called the
rebar.GetShapeDrivenAccessor()
 This accessor allowed me to use the
accessor.SetLayoutAsMaximumSpacing(spacingarrayLengthtruetruetrue);
function without SEHExceptions. So it is working.
Thommy_
hi @Anonymous
have a look at line ~400:
https://github.com/tt-acm/DynamoForRebar/blob/master/src/DynamoRebar/Nodes.cs
Best,
Thomas
Thomas Vogt
VDC Technology & Process Manager
Revit®, Dynamo, BIM  |  Training und Consulting in Stuttgart
E-Mail | Twitter | LinkedIn | YouTube | Facebook | Blog
