Getting the column lines
desdinova
desdinova
Options opt = new Options();
            opt.ComputeReferences = true;
            opt.IncludeNonVisibleObjects = true;
            View view=doc.ActiveView;
            IList<Reference> myRefs =uidoc.Selection.PickObjects(ObjectType.Element);
            foreach(Reference r in myRefs)
                FamilyInstance fi = doc.GetElement(r) as FamilyInstance;
                if (view != null)
                    opt.View = doc.ActiveView;
                GeometryElement ge = fi.get_Geometry(opt);
                if (ge != null)
                    foreach (GeometryObject go in ge)
                        if (go is GeometryInstance)
                            GeometryInstance gi = go as GeometryInstance;
                            foreach (GeometryObject goSymbol in gi.GetSymbolGeometry())
                                if(goSymbol is Line)
                                    Line line = goSymbol as Line;
                                            using (Transaction tx = new Transaction(doc))
                                                tx.Start("Transaction Name");
                                                DetailCurve dc = doc.Create.NewDetailCurve(doc.ActiveView, line);
                                                tx.Commit();
Hello friends
i want to get lines from columns
But when i draw the lines they are not in correct place
The code drows line in (0,0,0)
What am i doing wrong? How can i solve this.
Thanks in advance...
http://www.screencast.com/t/8KYFyVyhw7N
jeremytammik
You have to take the family instance or rather the geometry instance transform into account.
You can look at the ElementViewer SDK sample to see one possibility of handling this.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
