Getting Specification Data
trekkedout
trekkedout
Using the Revit API I am trying to get the AirTurn and Seam Data from a specification for a Fabrication Part. I see that the FabricationPart does have the Specification ID and I can get the Group and Name of the specification. I just need the last step on how to use this information to pull the specification .
jeremytammik
I would suggest analysing your model with RevitLookup. Do you know where to find this information in the user interface? If so, it should be pretty easy to find in RevitLookup, too. From that, you can determine how to access it programmatically as well.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
