We discovered an odd behavior with a rotated Crop Region when applying a View template from the Enable Temporary View Properties tool.
Here, I have a rotated Crop Region done the most common way:
Here's the result after the rotation, which is what we want:
Now, when I apply a View Template using the Enable Temporary View Properties tool, I get the following result:
Notice how it rotated the view back with its rotation center at the Project Base Point? This is caused by the Orientation parameter in the View Template being set to "Enable".
Now, when we restore the Temporary View Properties, here's what happens:
The view gets rotated back but the Crop Region remained at its Temporary View Properties location, which is incorrect!
Note that unchecking the "Enable" checkbox from the Orientation parameter in the View Template would not cause the Crop Region to move like that.
When simply changing the View Template from the Properties window, we do not get this problem. Here's the View Template applied:
Here's the original View Template is retored:
From what I understand, those two ways of applying a View Template should get the same results, right?
So, what's going on with the Temporary View Properties messing up the Crop Region? Can anyone help explaining what may cause this?
