Getting Linked elements visible in a 3D view
TomB.ADV
TomB.ADV
I know this may sound similar to other questions about the same topic but I didn't find a good solution.
My objective is to create a function which will get the all the elements in all Linked models Visible in a 3D view.
Afterwards, it should copy all the elements to the active document from which we called this function.
I can't figure out how to get the elements from the linked models effectively, I tried using the Bounding Box Filter
but it doesn't return any results, just some other 3D views, it worked for me before when applied to  non-linked
models but doesn't give me the same result here:
            var activeView = ActiveDoc.ActiveView;
            var activeBBox = activeView.get_BoundingBox(null);
            var activeOutline = new Outline(activeBBox.Min, activeBBox.Max);
            var result = new List<Element>();
            foreach (var doc in Documents)
                var collector = new FilteredElementCollector(doc)
                    .WherePasses(new BoundingBoxIntersectsFilter(activeOutline));
                result.AddRange(collector.ToElements().ToList());
I was able to solve this using ElementIntersectsSolidFilter, with some help from this post:
https://forums.autodesk.com/t5/revit-api-forum/create-solid-from-boundingbox/td-p/6330376
but I really didn't want to use this slow filter, any way this can be solved with a quick filter ?
var activeView = ActiveDoc.ActiveView as View3D;
            if(activeView == null) { return; }
            var activeSolid = solidBoundingBox(activeView.GetSectionBox());
                    .WherePasses(new ElementIntersectsSolidFilter(activeSolid));
                Transaction targetTrans = new Transaction(ActiveDoc);
                CopyPasteOptions copyOptions = new CopyPasteOptions();
                copyOptions.SetDuplicateTypeNamesHandler(new CopyUseDestinationHandler());
                targetTrans.Start("Copy and paste linked familys");
                ElementTransformUtils.CopyElements(doc, collector.ToElementIds(), ActiveDoc, null, copyOptions);
                ActiveDoc.Regenerate();
                targetTrans.Commit();
Thanks.
TomB.ADV
sorry for double posting.
