Create Solid from boundingbox
Message 1 of 12
I have a boundingbox and i need to convert in to a solid;
one possible solution is to use CreateExtrusionGeometry using a curveloop from some lines created from this boundingbox,
is there a better solution to accomplish this?
Replies (11)
Message 2 of 12
For now i used CreateExtrusionGeometry and its OK, but i would appreciate better solutions if any.
Message 3 of 12
jeremytammik
Do you want to generate a persistent Revit database element?
If so, the simplest solution is almost certainly to use a DirectShape element:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.50
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 4 of 12
Dear jeremy,
Thank you for your answer and helpful link.
Here, this solid is a temporary one to use with ElementIntersectsSolidFilter.
Since intersecting element is a brace ,  i couldn't use BoundingBoxIntersectsFilter;
if there were a  gradient boundingboxxyz in Revit API that Could be of great use for elements such as braces;
regards.
Message 5 of 12
owenmerrick
I was looking for an answer to the very same question, ended up here, and re-created your solution.  To save the next person a bit of typing, here's my code.  I'd love a more elegant answer but this works for my needs.
        public static Solid solidBoundingBox(Solid inputSolid)
            BoundingBoxXYZ bbox = inputSolid.GetBoundingBox();
            // corners in BBox coords
            XYZ pt0 = new XYZ(bbox.Min.X, bbox.Min.Y, bbox.Min.Z);
            XYZ pt1 = new XYZ(bbox.Max.X, bbox.Min.Y, bbox.Min.Z);
            XYZ pt2 = new XYZ(bbox.Max.X, bbox.Max.Y, bbox.Min.Z);
            XYZ pt3 = new XYZ(bbox.Min.X, bbox.Max.Y, bbox.Min.Z);
            //edges in BBox coords
            Line edge0 = Line.CreateBound(pt0, pt1);
            Line edge1 = Line.CreateBound(pt1, pt2);
            Line edge2 = Line.CreateBound(pt2, pt3);
            Line edge3 = Line.CreateBound(pt3, pt0);
            //create loop, still in BBox coords
            List<Curve> edges = new List<Curve>();
            edges.Add(edge0);
            edges.Add(edge1);
            edges.Add(edge2);
            edges.Add(edge3);
            Double height = bbox.Max.Z - bbox.Min.Z;
            CurveLoop baseLoop = CurveLoop.Create(edges);
            List<CurveLoop> loopList = new List<CurveLoop>();
            loopList.Add(baseLoop);
            Solid preTransformBox = GeometryCreationUtilities.CreateExtrusionGeometry(loopList, XYZ.BasisZ, height);
            Solid transformBox = SolidUtils.CreateTransformed(preTransformBox, bbox.Transform);
            return transformBox;
Message 6 of 12
jeremytammik
Dear Owen,
Thank you very much for your nice little sample code snippet.
I will gladly add it to The Building Coder samples, if I may.
Do you have a sample use case to demonstrate it doing something handy in a simple external command?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 12
owenmerrick
Upon selecting the planar face of a solid, two new solids are created - the two halves of the bounding box of the original, split by the plane of the selected face.
Hi Jeremy,
Here's a simplified version of how I'm using the bounding box code from yesterday. Whether this command meets the definition of "doing something handy" is debatable, but it's at least a functional command. I'm working on solid modeling tools for working with non-parametric masses using somewhat different formal logic than the built-in "form" tools. The step demo'd here is really just one piece of construction geometry on the way to a more complex, yet-unfinished tool, but it illustrates a few useful functions:
- from user face selection, retrieve both the face and the solid
- from solid, generate solid of bounding box
- insert solid into family context
This draws _very_ heavily on the sample code provided with the SDK, particularly the FreeFormElement sample and planar face selection filter.
For the sample code I copied the relevant bits into a fresh addin and zipped the whole thing up. This has the source, working(for me) .dll and sample image and rfa in the "doc" folder.
Best,
Owen
Message 8 of 12
Mustafa.Salaheldin
Can you please provide a sample RVT file for your "brace" family because I guess there is a direct way to do your intersection.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 9 of 12
BobbyC.Jones
Hi Jeremy,
As a use case, we use very similar code to do interference checking within a provided tolerance.
Owen,
I think you nailed it and I don't think there is a more elegant solution.
Bobby C. Jones
Message 10 of 12
jeremytammik
Wonderful, thank you ever so much for the perfect sample!
I summarised, polished and published this thread on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2016/09/solid-from-bounding-box-and-forge-webinar-4.html#2
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 11 of 12
owenmerrick
Jeremy,
Great, glad it worked out for you.  If I get my alternative massing modeling tools working well perhaps I'll post a follow up.
Bobby,
Thanks for the kind words.  I'm an architect rather than a proper programmer so sometimes I'm not sure if I'm missing an easier or more elegant way of doing things.
Best,
Owen
Message 12 of 12
516579196
Observer
Observer
namespace SizeAdjustment
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
public class WindowDoorOpening : IExternalCommand
public Autodesk.Revit.UI.Result Execute(ExternalCommandData commandData,
ref string message, ElementSet elements)
UIApplication uIApp = commandData.Application;
Application application = uIApp.Application;
UIDocument uIDoc = uIApp.ActiveUIDocument;
Document document = uIDoc.Document;
Selection selection = uIDoc.Selection;
View view = uIDoc.ActiveView;
//【】过滤墙体 用户选择
IList<Element> faces = uIDoc.Selection.PickElementsByRectangle();
Transaction trans = new Transaction(document, "LS");
trans.Start();
var solid = solidBoundingBox(view, faces.First());
var ds7 = DirectShape.CreateElement(document, new ElementId(BuiltInCategory.OST_GenericModel));
ds7.GetGeneratingElementIds(solid);
ds7.SetShape(new List<GeometryObject>() { solid });
trans.Commit();
return Result.Succeeded;
public static Solid solidBoundingBox(View view,Element inputSolid)
BoundingBoxXYZ bbox = inputSolid.get_BoundingBox(view);
edges.Add(edge0);
edges.Add(edge1);
edges.Add(edge2);
edges.Add(edge3);
