GetSubComponentIds does not return all nested elements
dchemanov
dchemanov
Hello, I have complex pipe fitting (please see file attached). When I call
GetSubComponentIds
I receive only one element, but I can't figure out why.
Thanks in advance!
jeremy_tammik
Happy Easter!
Your image looks like two separate fittings to me. I don't see any reason why one would expect them to be nested.
Furthermore, I believe there is a significant difference between subcomponents and nested components.
I don't see these two fittings being subcomponents of each other either, though.
If you look at them with RevitLookup, what do you see? I would assume that you see two separate family instances.
I.e., no nesting, no subcomponent.
dchemanov
It's a single family instance, and for this instance I get only one family instance id when I call GetSubComponentIds.
jeremy_tammik
Well, then I suggest that you open the family definition RFA document and explore its internal structure there. You can do so manually or programmatically using EditFamily:
https://www.revitapidocs.com/2023/56e636ee-5008-0ee5-9d6c-5f622dedfbcb.htm
You may also be able to navigate into it using RevitLookup via the Revit application list of documents.
