pyrevit gives the error on external python packages.
mathupathy_bXL6DS
mathupathy_bXL6DS
I am using pyqt5 python module in pyrevit. its read the inside programs of the pyqt5  packages and gives the error. i attached the image belowrevit error.png
jeremy_tammik
I don't know what might be causing this. Maybe raising an issue on the pyRevit repo will get you more targeted help?
https://github.com/eirannejad/pyRevit
mathupathy_bXL6DS
Hello jeremy sir,
I am already reinstalled 3 times pyrevit and the python path also correct
mhannonQ65N2
You cannot use PyQt from within IronPython. Try using CPython instead.
mathupathy_bXL6DS
hello sir,
  how  to I set cpython in pyrevit
christineR3C6N
I think it's because of it's path file. I just don't know where it's supposed to go!
If you go to User Variables, it's set for: C:\Users\Your User Name\AppData\Roaming\pyRevit-Master\bin
Is that where it normally goes? I'm also using One Drive Personal and One Drive Commercial. Those got screwed up too. I'm not sure if it's related.
Keep me updated!
