Get void form from beam
Message 1 of 9
How to read void forms from selected element in model.
My model element is structural member beam, there in my beam applied cell hole as s void cut,
So that cut I want to remove from this beam,
For that how to access member, family symbol & how to remove void.
Appreciate if you help to solve above.
-RK
Accepted solutions (3)
Replies (8)
Message 2 of 9
dragos.turmac
One possible option would be the following:
1. Get the Solid geometry of the FamilyInstance (your beam) and SolidUtils.Clone() it in a Solid called, say, "cutSolid";
2. Create a new (Sub)Transaction;
3. Delete the FamilyInstance that has created the void in the beam and call a Document.Regenerate();
4. Get the Solid geometry of your beam and use SolidUtils.Clone() again in a solid called, say, "fullSolid";
5. Rollback the transaction started at step 2;
6. Using BooleanOperationsUtils.ExecuteBooleanOperation, subtract "cutSolid" (step 1) from "full Solid" (step 4);
I used a similar code to extract the voids from a wall but I do not know if it works on beams/FamilyInstances, but it's worth a try.
Turmac Dragos
Pr. SW. Engineer
Message 3 of 9
GeomGym
Did you try InstanceVoidCutUtils.GetCuttingVoidInstances(element) ?  It will work if the void is applied appropriately.
Cheers,
Jon
Message 4 of 9
matthew_taylor
Hi @Anonymous,
If the void is in the family, you will probably need to open the family, delete the void, then reload the family into your project.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 5 of 9
Thanks for the information, i'm trying to solve.
-RK.
Message 6 of 9
How to delete void, any sample or reference if available kindly reply.
Thank you
-RK
Message 7 of 9
matthew_taylor
Hi @Anonymous,
This snippet worked okay in a family document in Revit 2017:
 Dim familyDoc As DB.Document = commandData.Application.ActiveUIDocument.Document
        Dim void As DB.GenericForm = _
            New DB.FilteredElementCollector(familyDoc).OfClass(GetType(DB.GenericForm)).Cast(Of DB.GenericForm).Where(Function(s) Not s.IsSolid).FirstOrDefault
        Using trans As New DB.Transaction(familyDoc, "Delete void")
            trans.Start()
            familyDoc.Delete(void.Id)
            trans.Commit()
        End Using
Cheers,
-Matt
Message 8 of 9
Thank you matthew.
now i got concept & how to delete cut with help of your reply.
-RK
Message 9 of 9
matthew_taylor
Great. Please post complete solution (favoured) or mark my solution as a solution.
Cheers,
-Matt
