viewport position
viewport position
sonicer
viewport position
sonicer
How can I get viewport position....
I am using boudarybox get min max and then I can get the center position..
But if I have viewport with name with underline  and then I drag the line point the boundarybox get the max size of this viewport this line.
How can I get center point of this viewport and how can I get the size of this line?
Then the possition is wrong.
FAIR59
the first part, getting the "clean" boundingbox is simple. Hide the label and extensionline with the TTT (temporary transaction trick) and determine the boundingbox.
        public BoundingBoxXYZ Get_BoundingBox_Clean(Viewport viewport)
            if (viewport == null) return null;
            Document doc = viewport.Document;
            string sheetName = viewport.get_Parameter(BuiltInParameter.VIEWPORT_SHEET_NAME).AsString();
            List<ViewSheet> _sheets = new FilteredElementCollector(doc)
            .OfClass(typeof(ViewSheet))
            .Cast<ViewSheet>()
            .Where(e => e.Name.Equals(sheetName))
            .ToList();
            Autodesk.Revit.DB.View sheetview = _sheets.FirstOrDefault();
            ElementType porttype = doc.GetElement(viewport.GetTypeId()) as ElementType;
            Parameter _showExtensionLine = porttype.get_Parameter(BuiltInParameter.VIEWPORT_ATTR_SHOW_EXTENSION_LINE);
            Parameter _labelTag = porttype.get_Parameter(BuiltInParameter.VIEWPORT_ATTR_LABEL_TAG);
            BoundingBoxXYZ bb = null;
            using (Transaction t = new Transaction(doc, "viewport"))
                t.Start();
                using (SubTransaction st = new SubTransaction(doc))
                    st.Start();
                    _showExtensionLine.Set((int)0);
                    _labelTag.Set(ElementId.InvalidElementId);
                    st.Commit();
                    st.Start();
                    doc.Regenerate();
                    bb = viewport.get_BoundingBox(sheetview);
                    st.Commit();
                t.RollBack();
            return bb;
the second part requires more acrobatics.
First hide the label, extension line and all annotations. Then make the cropbox as small as possible, and determine the boundingbox.
This is the "zero state" for comparison.
Next make the extension line Visible and again determine the boundingbox. If the box.Min and box.Max have moved, we can calculate the begin and endpoint of the extension line. If not (see picture: box.Min.X  == box.Min.X -"zero state")   then reposition the cropbox and repeat.
        public Line Get_Viewport_Extension_Line(Viewport viewport)
            try
                .Cast<ViewSheet>()
                .ToList();
                Autodesk.Revit.DB.View view = doc.GetElement(viewport.ViewId) as Autodesk.Revit.DB.View;
                BoundingBoxXYZ crop = view.CropBox;
                BoundingBoxXYZ newcrop = view.CropBox;
                XYZ pt1 = XYZ.Zero; XYZ pt2 = XYZ.Zero;
                using (TransactionGroup tg = new TransactionGroup(doc, "get_extensionline"))
                    tg.Start();
                    using (Transaction t = new Transaction(doc, "crop_Min_clean"))
                        t.Start();
                            st.Start();
                            view.get_Parameter(BuiltInParameter.VIEWER_VOLUME_OF_INTEREST_CROP).Set(ElementId.InvalidElementId);
                            view.AreAnnotationCategoriesHidden = true;
                            porttype.get_Parameter(BuiltInParameter.VIEWPORT_ATTR_SHOW_BOX).Set((int)1);
                            porttype.get_Parameter(BuiltInParameter.VIEWPORT_ATTR_SHOW_LABEL).Set((int)1);
                            newcrop.Min = new XYZ(crop.Max.X - 0.02, crop.Max.Y - 0.02, crop.Min.Z);
                            newcrop.Max = new XYZ(crop.Max.X, crop.Max.Y, crop.Max.Z);
                            view.CropBox = newcrop;
                            view.CropBoxActive = true;
                            st.Commit();
                        doc.Regenerate();
                        t.Commit();
                    BoundingBoxXYZ testcrop = view.CropBox;
                    using (Transaction t = new Transaction(doc, "crop_Max"))
                        t.Start();
                        doc.Regenerate();
                        _showExtensionLine.Set((int)1);
                        t.Commit();
                    BoundingBoxXYZ bb2 = viewport.get_BoundingBox(sheetview);
                    bool MoveRight = bb.Min.X.CompareTo(bb2.Min.X) == 0;
                    bool moveLeft = bb.Max.X.CompareTo(bb2.Max.X) == 0;
                    bool moveUp = bb.Min.Y.CompareTo(bb2.Min.Y) == 0;
                    bool moveDown = bb.Max.Y.CompareTo(bb2.Max.Y) == 0;
                    pt1 = new XYZ(bb2.Min.X, moveDown?  bb2.Min.Y: bb2.Max.Y, bb.Min.Z);
                    pt2 = new XYZ(bb2.Max.X, pt1.Y, bb.Min.Z);
                    if ( MoveRight || moveLeft || (moveUp && moveDown))
                            t.Start();
                            doc.Regenerate();
                            double MoveX = MoveRight ? 100 * view.Scale : -100 * view.Scale;
                            double MoveY = moveUp ? 100 * view.Scale : -100 * view.Scale;
                            newcrop.Min = new XYZ(newcrop.Min.X + MoveX, newcrop.Min.Y+ MoveY, crop.Min.Z);
                            newcrop.Max = new XYZ(newcrop.Max.X + MoveX, newcrop.Max.Y +MoveY, crop.Max.Z);
                            t.Commit();
                        BoundingBoxXYZ bb3 = viewport.get_BoundingBox(sheetview);
                        if (MoveRight) { pt1 = new XYZ(bb3.Min.X, pt1.Y, pt1.Z); }
                        else { pt2 = new XYZ(bb3.Max.X, pt2.Y, pt2.Z); }
                        double newY = bb3.Max.Y;
                        if (!moveUp && !moveDown)  newY = pt1.Y;
                        if (moveUp) { newY = bb3.Min.Y; }
                        pt1 = new XYZ(pt1.X, newY, pt1.Z);
                        pt2 = new XYZ(pt2.X, newY, pt2.Z);
                    tg.RollBack();
            return pt1.IsAlmostEqualTo(pt2)? null : Line.CreateBound(pt1,pt2);
            catch (Exception ex)
                TaskDialog.Show("catch", ex.ToString());
                return null;
sonicer
thx...
but then I get a Line.
How can I apply back size and position of this line to  underline of the viewport?
FAIR59
The resulting Line is a "clone" of the ExtensionLine
sonicer
thanks...
but still understand 😞
first I disable annotation and underline of the viewport than I get boundingbox min max...then I duplicate this viewport. - work ok.
For add to duplicated sheet I used your code of the line extension.....the input paramter is the viewport from the original sheets.
code Line.CreateBound(pt1, pt2);  realy create extension line that is moved with viewport?
FAIR59
there is no API method available to get / set the position of the ViewPort Title and ExtensionLine.
As far as I know,  what you want, can't be done.
Maltezc
Did you have any issues using this line?
get_Parameter(BuiltInParameter.VIEWPORT_ATTR_LABEL_TAG).Set()
I am trying to use mine for a different plugin but I get an error and I have to run it twice to have the viewtitle show up.
https://stackoverflow.com/questions/61641220/revit-api-c-sharp-how-to-set-view-title-on-viewport?nor...
