Get touching elements
shehab_fekry
shehab_fekry
I want to get the slabs that are on the edge of a beam as shown in figure .. is there any way that I can get these slabs
using ElementIntersectsElement or ElementIntersectsSolid won't work on this case.
jeremy_tammik
You should be able to use ElementIntersectsSolid with a slightly enlarged solid.
If your beam is aligned with one of the cardinal axes, you could even use a BoundingBoxIntersectsFilter instead, which is a quick filter. Just make the bounding box a bit bigger than the beam.
If worst comes to worst, you can also use the ReferenceIntersector to shoot rays from the beam to detect the neighbouring slab.
Finally, though, and best of all, we have an 11-year old solution to this very problem by The Building Coder:
https://thebuildingcoder.typepad.com/blog/2012/09/filter-for-touching-beams-using-solid-intersection...
Please let us know how you end up solving this in your specific case. Thank you!
shehab_fekry
Thank you, that solution helped a lot I made a solution where I used location line and with some transform functions and using solid.IntersectsWithCurve method I retrieved the slabs.
jeremy_tammik
Very glad to hear that you found a viable solution. Thank you for your appreciation.
jeremy_tammik
Thank you also for sharing your solution. I added it to the blog for future reference:
https://thebuildingcoder.typepad.com/blog/2023/10/no-geometry-touching-geometry-and-cut-geometry.htm...
cmoodyMNHEU
Observer
Observer
Jeremy's answer works great for curve based elements but I found his other answer here: https://thebuildingcoder.typepad.com/blog/2010/12/find-intersecting-elements.html works very well for all types of elements (curve and point based ex: walls & structural connectors). There are some API updates to perform on each code example he provides (curve based that he originally linked, and bounding box based that I linked here) but the logic is sound and holds up in Revit 2024 API.
kapitalaudio1234
the discussion is so helpful for me as a beginner ,sorry i just have a little question, getting a slab that is on the edge of a beam can be done in solibri as i know.what could be the difference of getting it with revit api or solibri ?
