Detaching model from workshared file changes ids
richard.schaffranek
richard.schaffranek
Hi I ran into the following problem:
1. I have downloaded a file from the acc cloud
2. I have opened it in REVIT and detached it
3. I have had a look at the uniqueIds of the two models.
Unfortunately they seam different, is this a correct observation?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @richard.schaffranek ,
This appears to be expected behavior.
In the documentation, you’ll find the statement: After you open the project, it no longer has any path or permissions information, and the default file name is the original filename with "_detached" appended. The project is in a state similar to when worksharing was first enabled; all elements in the project can be modified, but no changes can be saved back to the central model. If you save the project, it is saved as a new central model.
When you download a model from ACC (Autodesk Construction Cloud) and open it in Revit with “Detach from Central”, Revit treats it as a new, standalone model. During this process, it regenerates new UniqueIds for the elements.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
