Get the possible values for a family instance parameter
o_s_
o_s_
I have a parameter of family instance called DoorEnd.
The values of this parameter are a list of family types (OST_DuctTerminal).
I know the following way to get all possible values:
Element element =  document.GetElement(doorParameter.AsElementId());
IEnumerable<FamilySymbol> possibleValues = new FilteredElementCollector(document)
   .WhereElementIsElementType()
   .OfCategory(element.Category.BuiltInCategory)
   .OfClass(typeof(FamilySymbol))
   .Cast<FamilySymbol>();
But the value of this parameter is represented as NestedFamilyTypeReference:
As far as I understand, it is impossible to collect the list because it is nested.
If you have any ideas on how to collect possible values, please share them.
Thank you.
o_s_
Hello @jeremy_tammik
Do you have any ideas on how to do this?
sragan
I'm not sure I quite understand your example.  Just a guess, but are you sure you don't want the FamilySymbol.Family?
Looking at this example code to get the family name and family type of a duplex receptacle:
Get a specific family name and type, and place it:
FilteredElementCollector familyCollector = new FilteredElementCollector(doc);
familyCollector.OfClass(typeof(FamilySymbol));
                    FamilySymbol familySymbolToFind = null;
                    foreach (FamilySymbol familySymbol in familyCollector)
                        //To search by FamilySymbol name
if (familySymbol.Name == "receptacle" && familySymbol.Family.Name == "duplex")
                            familySymbolToFind = familySymbol;
                    }// end foreach
uidoc.PromptForFamilyInstancePlacement(familySymbolToFind);
FAIR59
the family can tell you the valid Ids for a familytype-parameter : GetFamilyTypeParameterValues
			FamilyInstance inst;
			Parameter doorend;
			Family fam = inst.Symbol.Family;
			ISet<ElementId> candidates = fam.GetFamilyTypeParameterValues(doorend.Id);
			IEnumerable<ElementId> symbols = new FilteredElementCollector(doc,candidates)
				.ToElementIds();
			// remove symbols from candidates
 			candidates.ExceptWith(symbols);
			// candidates now only contains the Ids of NestedFamilyTypeReferences
TripleM-Dev.net
Looks like that familytype used in the FamilyType parameter isn't a shared one, but one in the family itself and you can't get to that in a project, you would need to open the family.
See: https://revapidocs.com/2020.htm?id=ff71e3b0-4300-7d04-1356-a045b9a90407.htm
=> " nested FamilyType Element in the original Family Document where the family was defined."
So I suspect when a shared family is used for the FamilyType parameter a actual elementtype will be returned and the filter for the Category will work.
However if i'm correct the category can be obtained from the Parameter itself, but how depends on the Revit Version.
For Revit 2022 and up something like:
 Category.IsBuiltInCategory(Definition.GetDataType) => it it matches a builtin category it's a FamilyType and you can get the category from it.
See https://revapidocs.com/2022.htm?id=efbd8409-b82b-11d8-4b20-65ffc27b750e.htm
