How to rename a GraphicsStyle?
attone
Observer Observer
attone
Observer
Observer
Hi Guys
I have encounter a problem which I don’t know how to solve. I am clueless right now.
I need to rename GraphicsStyle. For example, I want to change the name “LH-A-modi” to “modi”.
First, I simply set the name of a GraphicsStyle to a new name, but it throwed a exception. I can’t assign a new name to a GraphicsStyle.
This is the exception:
Secondly, I create a new GraphicsStyle with a specified name, then I delete the old one. It work fine with the unused ones. If some elements have used the GraphicsStyle, it will throw a exception.
This is how I coded:
So I can’t delete this one.
At last, I try to replace the GraphicsStyle with the newly created one. It will throw a exception. The SubCategories is read-only
Please Let me know if this is a solution.Thanks
SONA-ARCHITECTURE
Hi , do you find a solution to rename GraphicsStyle?
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
SONA-ARCHITECTURE
I found a solution :
First create a new GraphicsStyle cloned from the current to rename
Reassign all instances lines of the document to the cloned one
Delete the old one
Create a new GraphicStyle cloned from the precedent clone, but now, create with the original name.
Delete the first clone.
Pierre NAVARRA
SONA-Architecture.
TripleM-Dev.net
Just rename the subcategory with the same name under the Lines main category, those are the linestyles (aka the GraphicStyle you mean)
GraphicsStyle is nothing more than a Category, as the top-level categories can't be renamed and some builtin sub-categories, but all other sub categories can be renamed.
And in the case of the LineStyles, it's the Lines Category.
