Get / Retrieve Plug-in function run event
MehtaRajesh
MehtaRajesh
Hello all,
I am able to track File Save Event as below
public Autodesk.Revit.UI.Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
this.uidoc = commandData.Application.ActiveUIDocument;
Autodesk.Revit.ApplicationServices.Application revitApplication = commandData.Application.Application; Autodesk.Revit.ApplicationServices.Application app; Autodesk.Revit.UI.UIApplication m_app; m_app = commandData.Application;
app = m_app.Application;
commandData.Application.ActiveUIDocument.Document.DocumentSaving += Document_DocumentSaving; MessageBox.Show("We are in process", "TITLE", MessageBoxButtons.OK, MessageBoxIcon.Warning);
return Autodesk.Revit.UI.Result.Succeeded;
private void Document_DocumentSaving(object sender, Autodesk.Revit.DB.Events.DocumentSavingEventArgs e)
MessageBox.Show("We are at Save event", "TITLE", MessageBoxButtons.OK, MessageBoxIcon.Warning);
My Requirement is to track the external plug-in button press event, (If say One external plug-in loaded in ribbon, and if user presses one of the button, function need to notify) and prior OR after running that function i need to run my own function.
Thanks in advance for your kind support.
Raj
MehtaRajesh
Hello All,
Any update on my requirement from Revit API developer specialists OR from Autodesk Product expert ?
Raj
jeremy_tammik
If you just want to keep a log of when your add-in code is executed, the easiest solution is probably to implement a simple logging functionality in the add-in code itself.
MehtaRajesh
Thanks for your reply,
But I need to track when particular button pressed from third party plug-in (e.g. UNIFI), for which i do not have control (Source-code) hence i can not do any changes in that plug-in.
Is there any reactor kind of mechanism using which i can notify button pressed ?
Thanks in advance for your further help / support
Raj
jeremy_tammik
I do not believe the Revit API provides a dedicated method or event for this right out of the box.
There are a number of indirect solutions that you can use, though:
There are certainly other further possibilities to achieve this.
MehtaRajesh
Thanks a lot, will do required r&d and if able to solve issue, will update it for wider audience
