Resize Elevation Crop Region
inouizi
inouizi
Apologies if the format of the post is not up to standards or if the topic has already been addressed somewhere.
I did do a lot of searches both here and on The Building Coder pages and couldn't find a solution or an explanation.
I am not really sure how to ask this but here it goes:
I want to be able to resize the elevation crop region based on locations of grids and levels on the view.
I seem to make the south/north elevations (elev-A) work pretty well, but I am not able to make the east elevation (elev-B) work.
elev-A
elev-B
For elev-B, I end up with a 1' long crop region. The top and bottom are correct but the left and right extents are not.
This is the python code I am using on the elev-A which is working perfectly:
aview = doc.ActiveView
#find visible grids on current view
gridsonview = []
for g in grids:
    if g.CanBeVisibleInView(aview):
        gridsonview.append(g)
cborg = aview.CropBox.Transform.Origin
if aview.ViewDirection.Y == -1:
    #find grid x coordinates
    gridmins = [gm.GetCurvesInView(DB.DatumExtentType.Model, aview)[0] \
                                    .GetEndPoint(0).X for gm in gridsonview]
    gridsbymmin = dict(zip(gridmins, gridsonview))
    #grids on view ordered by coordinates
    sorted = [gridsbymmin[vminvalue] for vminvalue in sorted(gridmins)]
    tz = Transaction(doc, "South facing view crop box")
    tz.Start()
    aview.CropBoxActive = False
    #left grid X
    lgx = sorted[0].GetCurvesInView(DB.DatumExtentType.Model, aview)[0] \
                    .GetEndPoint(0)
    #right grid X
    rgx = sorted[-1].GetCurvesInView(DB.DatumExtentType.Model, aview)[0] \
                    .GetEndPoint(0)
    #grid top Z
    tgy = sorted[0].GetCurvesInView(DB.DatumExtentType.Model, aview)[0] \
                    .GetEndPoint(1)
    #grid bottom Z
    bgy = sorted[0].GetCurvesInView(DB.DatumExtentType.Model, aview)[0] \
                    .GetEndPoint(0)
    min = XYZ(lgx.X - cborg.X - offset, bgy.Z - cborg.Z - 1, 0)
    max = XYZ(rgx.X - cborg.X + offset, tgy.Z - cborg.Z + 1 + (bubblesize * aview.Scale), 0)
    nsb = BoundingBoxXYZ()
    nsb.Min = min
    nsb.Max = max
    aview.CropBox = nsb
    aview.CropBoxVisible = True
    aview.CropBoxActive = True
    tz.Commit()
With this logic.. what should the nsb BoundingBox coordinates be for elev-B so that I get the correct crop region?
Thank you in advance!
inouizi
no takers? 😞
mhannonQ65N2
Have you tried replacing 'X' with 'Y' for elevation B?
inouizi
Yes I did @mhannonQ65N2 , that didn't work.
What did work, is using ViewCropRegionShapeManager
https://www.revitapidocs.com/2019/2610cb66-5dae-9fc8-4e83-7dfe88085abb.htm
Still wrapping my head around it, but I think I'm starting to see the light at the end of the tunnel!
Thanks!
