Get position referenceplane in familyinstance
sonicer
sonicer
Is it possible get position of referenceplane in familyinstance that is not aligned with some mass/object.
Only alone stay reference in familyinstance.
My way:
The referenceintersector does't detect this reference.
need other way.
need direction and position of this referenceplane.
thx.
FAIR59
sonicer
thanks...but I think it only show direction....
FAIR59
From the dimension in the code, you could also find a point on the plane.
Howevere there is an alternative:
You can create a sketchplane using the reference, and find origin and normal from the plane of the sketchplane.
Reference r = inst.GetReferences(FamilyInstanceReferenceType.Left).FirstOrDefault();
if (r==null) return;
XYZ origin = XYZ.Zero;
XYZ normal = XYZ.Zero;
bool found=false; using (Transaction t = new Transaction(doc,"create sketchplane")) { t.Start(); SketchPlane sk = SketchPlane.Create(doc,r); if (sk!=null) { Plane pl = sk.GetPlane(); origin = pl.Origin; normal = pl.Normal;
found = true; } t.RollBack(); }
aignatovich
Awesome!
I think we should call @jeremytammik to publish this solution in his TBC blog.
jeremytammik
Dear Alexander,
With great pleasure!
Thank you for the suggestion.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
