Loading macro failed error.
recepagah12
recepagah12
Loading the macro failed. Rebuilding the module may resolve this issue.
When i first create a module, i can't add a macro to it. I can edit the module and build. Also Revit is saying build the mdoule is succesful but neverthless i can't add macro or run the module-macro.
FAIR59
Check your macro security settings.
recepagah12
I alread did this. I need another solution. I create module but can't add macro or run it. Do i install again?
stever66
You won't be able to run anything until you have successfully created and built a macro.  Make sure the module is selected when you press the macro button.
you can also add a macro manually.  Inside the edit window for the module, right before the last }, type:
public void MyMacro()
Your macro code goes here.....
recepagah12
I will try what you said. Nevertheless, there is doubt in my mind. Because, when i add module and select it, still the macro adding button is offline. I hope your way will help me. Thanks.
stever66
Hopefully that worked since you marked it as solved.
If not, you could always start a new Module, and start a new Macro in that Module.  Then build it before adding any other code.  It should build without any problems.
Then add your code.  If it won't build after that, its something wrong with your code.
