Get Parameter Unit in Revit 2021
jmyr
jmyr
Hi guys,
How do i get the exact unit from specific parameter for example
Calculated Heating Load = W
Calculated Heating Load per area = W/m²
and so on..
Parameter parameter = SELECTEDZone.get_Parameter(BuiltInParameter.ZONE_CALCULATED_COOLING_LOAD_PARAM);
ForgeTypeId units = parameter.GetUnitTypeId();
jeremytammik
Please read the What's New description on the Forge type id and its use:
https://thebuildingcoder.typepad.com/blog/2020/04/whats-new-in-the-revit-2021-api.html#4.1.3
Maybe the discussion of Boost your BIM will help:
https://thebuildingcoder.typepad.com/blog/2020/07/virtual-au-and-aec-hackathon-units-and-das-job.htm...
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks for the info. It seems that as of Revit 2021 the below methods have been marked Obsolete.
  • UnitUtils.GetSpecTypeId()
  • UnitUtils.GetUnitType()
  • UnitUtils.GetUnitTypeId()
  • UnitUtils.GetDisplayUnitType()
  • UnitUtils.GetSymbolTypeId()
  • UnitUtils.GetUnitSymbolType()
If I have a Revit Parameter object that contains an area in square meters (25.4 sqM), can you help me identify how I could extract the number (25.4) and the unit type (sqM) from the Parameter? I'm aware I can use Parameter.AsValueString(), but this will give me the concatenated version. I'm trying to get the numbers and the units separately, and it's proving to be a bit tricky.
Thank you in advance.
Dear Charlie,
Personally, for simple units such as length and area, I just implement the conversion myself, cf., e.g., The Building Coder samples:
https://github.com/jeremytammik/the_building_coder_samples
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/Util.cs#L1206-L...
Thanks @jeremy_tammik
These are always helpful.
My current project requires me to travers all the parameters of various elements from different categories. I can easily get the parameter name, and value.
ParameterData paDa = new ParameterData();
paDa.ParameterName = param.Definition.Name;
switch (param.StorageType)
     case StorageType.String:
          paDa.ParameterValue = param.AsString(); break;
     case StorageType.Integer:
          paDa.ParameterValue = param.AsInteger().ToString(); break;
     case StorageType.Double:
          paDa.ParameterValue = param.AsDouble().ToString(); break;
     default:
          paDa.ParameterValue = param.AsValueString(); break;
My next goal is to get the unit type (mm, cm, cm2, ft, ft2, etc.). Since some of the parameters have complex unit types such as w/m2, I can't predict all the unit types to manually code them in. In order to get the UnitTypeID I'm using
ForgeTypeId unitTypeId = param.GetUnitTypeId();
For my application it's important to have the parameter name, parameter value, and parameter unit type as separate fields, so that I may operate / query them individually. The obvious problem is that not every parameter has a Unit Type. So I have to run the line of code above in a try/catch block. Is there a way to identify if the parameter has a Unit Type before trying to execute the line of code above? I have a hunch the application is taking a performance hit since the try / catch block triggers quite often.
Thank you.
