Get linked elements by OfClass
Hi!
I want to get a copy of all Ducts from a linked Revit file. The copied elements must be at the same location as their linked counterpart.
I tried this sample: copy-family-between-documents-via-api
But as I understand as a novice in Revit, Duct can't be consider as a Family instance because it is a Build in Family.
If you guys know a look alike sample, it could be something to start with!
Thanks!
Well i found this one which perfectly fit my needs !
accessing-data-from-linked-file-using-revit-api
