Copy to selected levels faster
Message 1 of 8
Hi
In revit there is a feature called copy to selected level. How do  automate this feature but the challenge is speed. The objective is to reduce the time to do so.
Thanks & Regards
Thanks & Regards
Sanjay Pandey(BIM[Revit] Developer)
Replies (7)
Message 2 of 8
Mustafa.Salaheldin
Please refer to my solution in the following topic:
http://forums.autodesk.com/t5/revit-api/a-question-about-suppressing-warning-messages-in-revit/m-p/6...
Tell me if it satisfies your need or you may need a little modification.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 3 of 8
Dear mustafa,
I think I didn't chose right words for the problem. So I will rephrase:
say for example I have a few walls doors windows etc on level  1.
now I select them all and copy them
now from the paste menu I select paste - aligned to selected levels.
choose all other levels
and click ok.
The selected elements gets copied to all the selected levels.
All This was manual part.
What I am trying to achieve:
Create a tool using copies the elements to selected levels in half the time.
Thanks & Regards
Message 4 of 8
Mustafa.Salaheldin
Ok now I got it.
It is so simple.
First prompt the user to select the elements to be copied using Selection.PickObjects Method.
Then use a filter to collect all the views you want to copy the elements to.
Iterate through the views and apply the ElementTransformUtils.CopyElements Method (View, ICollection<(Of <(<'ElementId>)>)>, View, Transform, CopyPasteOptions).
Note: all the above steps must be done from 2D view and to 2D views.
If this reply satisfies your answer don't forget to mark it as a reply.
Cheers
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 5 of 8
Dear mustafa,
Is not same as copy and paste - aligned to selected levels.
My objective here is to reduce time by minimum half the time doing it manually
Thanks & Regards
Message 6 of 8
Mustafa.Salaheldin
Sorry I'm bit confused, can you please clarify more?
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 7 of 8
Say for example manually copy paste to all levels take 10 mins. I want to
write code which does in 5 mins
Message 8 of 8
Mustafa.Salaheldin
I see, no I guess this is out of our scope Smiley Very Happy
¯\_(ツ)_/¯
Mustafa Salaheldin
