- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone:
I am a newcomer to develop RevitAPI,now I have a question about suppressing warning messages.
when we use "Paste/ AlignedToSelectedLevels"command to paste elements, if some of these are overlap, Revit displays the following warning message:
Now I creat a addin, in which I use “uiapp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.AlignedToSelectedLevels));” to paste some elements ,meanwhile I want to suppressing this warning messages and get these messages .
This is my code:-
using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.Revit.UI; using Autodesk.Revit.DB; using Autodesk.Revit.UI.Selection; using Autodesk.Revit.Attributes; using Autodesk.Revit.DB.Plumbing; using Autodesk.Revit.DB.Mechanical; using Autodesk.Revit.DB.Electrical; using Autodesk.Revit.DB.Architecture; using Autodesk.Revit.DB.Structure; using Autodesk.Revit.DB.Events; using System.Threading; namespace DeleteWarningElement { [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)] [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)] [Autodesk.Revit.Attributes.Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)] public class Class1 : IExternalCommand { public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { UIApplication uiapp = commandData.Application; UIDocument uidoc = uiapp.ActiveUIDocument; Document doc = uidoc.Document; uiapp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.AlignedToSelectedLevels)); Transaction transaction = new Transaction(doc, "BIM"); FailureHandlingOptions options = transaction.GetFailureHandlingOptions(); options.SetFailuresPreprocessor(new FailurePreproccessor()); transaction.SetFailureHandlingOptions(options); transaction.Start(); TaskDialog.Show("1", "12"); Thread.Sleep(5000); transaction.Commit(); return Result.Succeeded; } } public class FailurePreproccessor : IFailuresPreprocessor { public FailureProcessingResult PreprocessFailures(FailuresAccessor failuresAccessor) { IList<FailureMessageAccessor> failList = failuresAccessor.GetFailureMessages(); if (failList.Count == 0) { TaskDialog.Show("1", failList.Count().ToString()); return FailureProcessingResult.Continue; } foreach (FailureMessageAccessor failure in failList) { TaskDialog.Show("1", "123"); FailureDefinitionId failID = failure.GetFailureDefinitionId(); if (BuiltInFailures.CopyPasteFailures.CannotDuplicateWarn==failID) { failuresAccessor.DeleteWarning(failure); } } return FailureProcessingResult.ProceedWithCommit; } } }
When I executed the code, I found this warning was not suppressed. I also found that“ Transaction transaction = new Transaction(doc, "BIM"); ” is a null operation, so what is Transaction of PostCommand in Revit .
how to solve this problem?
Looking forward to your reply!
GoodLuck!
