Get Length, Width of Structural Column, to set in a isolated foundation.
I writing a code for cauculating the isolated foundation for a especifc column, dependeing fo it dimensions and force Z
i alredy get all informations, and the column like a element class, but i don't now how can i get the Length and Width of this instance sleected. Can someone help me ?
architect.bim
Hi!
To extract length and width you need to get parameter values. Length is a built-in intance parameter. You can get i with get_Parameter method.
length = element.get_Parameter(BuiltInParameter.INSTANCE_LENGTH_PARAM).AsDouble()
Width is probably type parameter. To extact it first you need to get type object. And I think this parameter is not system. So you need to use LookupParameter method and specify its name. In my case it is 'b'.
width = doc.GetElement(element.GetTypeId()).LookupParameter('b').AsDouble()
P.S. Exapmles are written in Python. I hope you'll be able to adapt it for C# if you use it.
Maxim Stepannikov | Architect, BIM Manager, Instructor
binsaugust
Community Visitor
Community Visitor
Could you please share the full code showing how to import above data?Sorry am new to pyRevit /rpw and trying to learn how to impot dimension to a flexform.
