Cannot access the paper size and paper source of current printer
luis7SJJ3
luis7SJJ3
I called External Event from Async Method with event.Rise() so now no exception related to Transaction. An exception raised which is related to PrintManager Access.
Below is the line of code on which i am getting exception. This code is inside Transaction
PrintManager pMgr = doc.PrintManager;
Exception on this line is
Exception thrown: 'Autodesk.Revit.Proxy.Exceptions.InvalidOperationExceptionProxy' in RevitDBAPI.dll
Additional information: Cannot access the paper size and paper source of current printer
This code line is inside External Event, I tried to put that code line outside the external Event and inside Async method but same exception
I am pretty sure that this exception due to either Async or Externel Event but don't know how to come out of it.
Any ideas?
@RPTHOMAS108
RPTHOMAS108
Would need more of an example.
Try without async is my initial advice.
To my mind the whole purpose of async was to call a function and continue without waiting for it to complete, some resources you probably can't avoid waiting for. There is an example of using async with ExternalEvents but it isn't a required ingredient for them.
I've not used async with external events. I used it recently outside of API but I had full control over both aspects of that i.e. the task I wasn't waiting for and the overall task that didn't need me to wait for that part of it.
