Get cutting void instances in the floor
minet.axel
minet.axel
I have a floor on which a familyinstance is inserted on the face of the floor (the instance to host: the floor). I checked in the family the "Cut with Void When Loaded" parameter so that the void created on the floor. I want to retrieve the instance that creates the void in the floor.
I did some research, and found this link: http: //thebuildingcoder.typepad.com/blog/2011/06/boolean-operations-and-instancevoidcututils.html But when I use InstanceVoidCutUtils.GetCuttingVoidInstances(element) returns an empty list.
jeremytammik
This discussion should provide hints to all you need:
http://thebuildingcoder.typepad.com/blog/2015/07/intersect-solid-filter-avf-and-directshape-for-debu...
I hope it helps.
Please let us know how it goes and how you end up resolving this.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
minet.axel
lsdlfs
I want to deduce the voids in the floor. But when I use ElementIntersectsElementFilter or ElementIntersectsSolidFilter, I do not have the expected result (no elements intersect).
First case : area = 607.558m2 and Volume = 243.023m3
Second case : area = 607.558m2 and Volume = 243.023m3
 Family parameter
 FamilyInstance cutting
Solid solid = floor.get_Geometry(new Options())
.OfType<Solid>() .Where<Solid>(s => null != s && !s.Edges.IsEmpty) .FirstOrDefault(); FilteredElementCollector intersectingInstances = new FilteredElementCollector(doc) .OfClass(typeof(FamilyInstance)) .WherePasses(new ElementIntersectsSolidFilter(solid)); int n1 = intersectingInstances.Count<Element>(); intersectingInstances = new FilteredElementCollector(doc) .OfClass(typeof(FamilyInstance)) .WherePasses(new ElementIntersectsElementFilter(floor)); int n = intersectingInstances.Count<Element>();
Here "n" and "n1" are equal to 0.
FAIR59
try using
                List<ElementId> intersectingInstanceIds = floor.FindInserts(false,false,false,true).ToList();
minet.axel
I have done some tests and here are my returns.
FindInserts returns FI_1 even if its host (Level 3) is not the floor. Its good.I think we can say that the problem is solved.
Thank you FAIR59 ;).
jeremytammik
Many thanks yet again to Fair59 for his accurate and succinct solution, and to Axel for raising the issue and confirming it!
Once again, I think this needs to be preserved and easily found, so I edited and shared on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2017/06/findinserts-determines-void-instances-cutting-a-flo...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
