Create dimension based on the column center
Hi
I used below code to create a Dimension.
Reference refElement0 = sel.PickObject(ObjectType.Element, "selectColumn0");
            Reference refElement1 = sel.PickObject(ObjectType.Element, "selectColumn1");
            FamilyInstance familyInstance0 = Doc.GetElement(refElement0) as FamilyInstance;
            FamilyInstance familyInstance1 = Doc.GetElement(refElement1) as FamilyInstance;
            FaceArray faces0 = GetFaceArrayOfFamilyInstance(familyInstance0);
            FaceArray faces1 = GetFaceArrayOfFamilyInstance(familyInstance1);
            Face face0 = null;
            Face face1 = null;
            foreach (Face face in faces0)
                XYZ faceNormal = GetFaceNormal(face);
                if (faceNormal.IsAlmostEqualTo(new XYZ(0, -1, 0)))
                    face0 = face;
                    break;
            foreach (Face face in faces1)
                    face1 = face;
                    break;
            ReferenceArray refArray = new ReferenceArray();
            refArray.Append(face0.Reference);
            refArray.Append(face1.Reference);
            using (Transaction t = new Transaction(Doc, "CreateDimension"))
                t.Start();
                LocationPoint locationPoint0 = familyInstance0.Location as LocationPoint;
                LocationPoint locationPoint1 = familyInstance1.Location as LocationPoint;
                Line lineDimension = Line.CreateBound(locationPoint0.Point, locationPoint1.Point);
                Doc.Create.NewDimension(Doc.ActiveView, lineDimension, refArray);
                t.Commit();
As expected,the reslut is like below:
But.. I really want is like below ..which is to create dimension based on the column center like manually createing the dimension from revit UI (can select the center line of a column). And what does this bule line represent, Face? Plane? Line?
Any idea on how to implement this? Thx!
jeremytammik
Yes, I hope so.
Check out this recent discussion:
http://thebuildingcoder.typepad.com/blog/2017/05/api-access-to-family-instance-references.html
I hope it helps.
Please let us know how it goes and how you end up resolving this.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy,
Sorry for the late reply.
I refered to Picking Pairs and Dimensioning Family Instance Origin and get the column origin line for creating the dimension. It worked.
Thanks a lot!
