get corner points of the curtain panel based on (nesting) concept mass family
Ning_Zhou
Ning_Zhou
similar to the comment by Charlie Portelli in the following link:
http://thebuildingcoder.typepad.com/blog/2010/05/curtain-wall-geometry.html
obviously it's different from the normal curtain wall or curtain system approach, what is the proper procedure? thanks in advance.
jeremytammik
Dear Ning,
Thank you for your query.
I am checking with the development team and will let you know what I find out.
Meanwhile, could you provide a minimal reproducible case to demonstrate the issue?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Ning_Zhou
thanks Jeremy.
i uploaded the file here for your reference, just the simplified RVT, how to get 4 points of the glass panel? didn't have any code yet as no idea how to do it.
Cheers,
Ning
jeremytammik
Dear Ning,
Thank you for the sample file. I passed it on and will let you know as soon as I hear anything back.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
