ViewPrinter sample select view/sheets issue
b_ralphs
b_ralphs
I'm testing the ViewPrinter sample from the SDK in Revit 2014.
When I click on the select view/Sheet Set & check some sheets, then OK, & then OK on the main print dialog, it doesn't print the sheets I selected. It's like <In-Session> settings don't get saved & it just uses whatever sheet set was previosly selevted. Can anyone help me fix this?
b_ralphs
Has no one used this sample?
Is there a better option for sheet selection?
augusto.goncalves
Indeed it seems this sample is not saving the information. If you look at the 'OK' button, nothing is done, so the information will not pass back... in fact, it seems to use only the options saved with name, not considering in case was selected on the list....
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
miketurpin_innovatingfutures
Do you know if this issue has been fixed yet?
What code needs to be executed on clicking the OK button?
Mike
