Get coordinates of Rebar distribution path
htlcnn
htlcnn
I created a stirrup rebar with layout rule of Maximum Spacing. I want to get the absolute coordinates of the distribution path but in the API the GetDistributionPath() (or GetShapeDrivenAccessor().GetDistributionPath() in 2018) method returns a Line beginning at (0,0,0).
How do I get absolute start and end coordinates of rebar distribution path?
Thanks!
htlcnn
Rebar set is based on the first rebar. Position of the first rebar is the root of the DistributionPath. The first rebar is positioned by its constraints.
Organon
@htlcnn,
Colud you please share your solution? Thanks.
Arquitectura | Análisis CAD & BIM | Diseño Paramétrico | Programación
BIM-METADATA | LinkedIn | YouTube
htlcnn
@Organon it's been 4 years and I can't recall exactly what I struggled back then, either details of the solution.
I've had a quick look up at API and can give some hints for shape driven rebars:
Rebar.GetShapeDrivernAccessor() is your friend.
- First, you can use ComputeDrivingCurves to find first rebar's geometry.
- Then, GetBarPositionTransform gives you the transform that represents relative position of the specific rebar in the set, you can use that Transform to find exact position of the rebar.
Organon
@htlcnn,
Thanks for your answer.
I actually tried, but the transformation obtained using the GetBarPositionTransform is just a translation along the distribution path, and the distribution path always begins at 0,0,0. I'm trying to get the references shown in the image. Any ideas?
