AddInCommandBinding crash revit
minet.axel
Message 1 of 1
minet.axel
I use AddInCommandBinding to find the "Model Line" command. To do this from the revit application:
- Link the command "ID_OBJECTS_PROJECT_CURVE".
- Subscribe to the BeforeExecuted event.
- Creating an ExternalEvent to use a modelessDialog (FormNoElementHost)
- button2_Click launches externalEvent
- ExternalEvent (ExternalEventCreateCodeLine) launches the modelLine command
My problem is that revives crash at the end of the event "modelLineCommand_BeforeExecuted". This only happens when I debug the application. Indeed I noticed that if I run Revit then run the command without going through visual studio, my revit does not crash
 class AppRevit : IExternalApplication
        public static AppRevit thisApp = null;
        public static String s_commandToModelLine = "ID_OBJECTS_PROJECT_CURVE"; // ModelLine
        public static RevitCommandId s_commandId;
        public Result OnShutdown(UIControlledApplication application)
            if (s_commandId.HasBinding)
                application.RemoveAddInCommandBinding(s_commandId);
            return Result.Succeeded;
        public Result OnStartup(UIControlledApplication application)
            thisApp = this;
            //binding commands
            s_commandId = RevitCommandId.LookupCommandId(s_commandToModelLine);
            if (!s_commandId.CanHaveBinding)
                ShowDialog("Error", "The target command" + s_commandToModelLine +
                    " selected for disabling cannot be overridden");
                return Result.Failed;
            try
                AddInCommandBinding modelLineCommand = application.CreateAddInCommandBinding(s_commandId);
                modelLineCommand.BeforeExecuted += modelLineCommand_BeforeExecuted;
            catch (Exception)
                ShowDialog("Error", "This add-in is unable to disable the target command " + s_commandToModelLine +
                    "; most likly another add-in has overridden this command.");
        void modelLineCommand_BeforeExecuted(object sender, Autodesk.Revit.UI.Events.BeforeExecutedEventArgs e)
            ShowDialog("BeforeExecuted", "modelLineCommand");
        private static void ShowDialog(string title, string message)
            TaskDialog td = new TaskDialog(title)
                MainInstruction = message,
                TitleAutoPrefix = false
            td.Show();
public partial class FormNoElementHost : Forms.Form
        ExternalCommandData _commandData;
        public ExternalEvent ExEvent { get; set; }
        public FormNoElementHost(ExternalCommandData commandData)
            : this()
            _commandData = commandData;
        public FormNoElementHost()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            Family family;
            string message;
            UtilsFamily.LoadFamily(_commandData.Application.ActiveUIDocument.Document, out family, out message);
        private void button2_Click(object sender, EventArgs e)
          //  System.Windows.Forms.MessageBox.Show("Other");
          //  _commandData.Application.PostCommand(AppRevit.s_commandId);
            ExEvent.Raise();
 public class ExternalEventLigneModeleCréer : IExternalEventHandler
        public void Execute(UIApplication app)
            //AppRevit.thisApp.CréationSPE.CréerLigneModele();
            app.PostCommand(AppRevit.s_commandId);
        public string GetName()
            return "External Event Créer ligne modele";
 [Transaction(TransactionMode.Manual)]
    public class FormNoElementHostCommand : IExternalCommand
        public Autodesk.Revit.ApplicationServices.Application RevitApp;
        ExternalEvent _exEvent;
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            ExternalEventLigneModeleCréer handlerLigneModeleCréer = new ExternalEventLigneModeleCréer();
            _exEvent = ExternalEvent.Create(handlerLigneModeleCréer);
            FormNoElementHost form = new FormNoElementHost(commandData);
            form.ExEvent = _exEvent;
            form.Show();
Replies (0)
