- Mute
- Permalink
- Report
Dear community,
i am facing problems to retrieve the blend object of the window in the simple model attached.
I tried already with the filteredElementCollector in many ways (https://forums.autodesk.com/t5/revit-api-forum/how-to-extract-a-list-of-all-solids-from-a-family/m-p...) and looked for Blends in the elementIds of the wall and the window deleted with the temporary transaction trick.
The task i am trying to achieve with it is a quantity takeoff for a operational energy demand calculation. Thereby, i also extract the geometry of the windows and doors to visualize the thermal model to a user. So far, i put a bounding box around every window or door placed with a blend. Unfortunately, some windows (like the one in the model) have linked some element that makes the bounding box much wider than the clear width. So i would prefer to access the blend geometry. As i have all the windows and doors in my internal data structure, a reference from the window to the blend it is using would be the ideal solution. In Revit Lookup, i didnt find any link between the objects so far...
Thanks a lot,
Kind Regards
Lothar
