Get all Tags
Get all Tags
david_rock
Get all Tags
david_rock
The following code does not include the tags in a model.
Dim objCollectorAllFamilyInstance As FilteredElementCollector = New FilteredElementCollector(activeDBdoc).OfClass(GetType(FamilyInstance))
I need a similar line to give me all the tags (or IndependantTag) elements. However OfClass(GetType(IndependentTag)) does not work.
Kind Regards
David
jeremytammik
Dear David,
I very strongly suggest you install RevitLookup and take a closer look at the tags you wish to select using that tool:
https://github.com/jeremytammik/RevitLookup
It will tell you all you need to know in just a few clicks, such as .NET class, Revit category, etc.
Tags are not family instances.
You can also look at the Revit API help file to see that it defines a separate class for independent tags, very imaginatively named IndependentTag:
http://www.revitapidocs.com/2018.1/e52073e2-9d98-6fb5-eb43-288cf9ed2e28.htm
Try filtering for those and see what you get.
Please install RevitLookup and check it out yourself first!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
david_rock
Thank you for your suggestions, yes I use RevitLookup regularly. However in this case it didn't provide me with any ideas.
I ended up using CategoryType to find the Annotation categories.
It is not very elegant, so I would welcome alternative solutions.
Dim ListOfElementId As New List(Of ElementId)
Dim objCategories As Categories = objDocument.Settings.Categories
    For Each objCategory As Category In objCategories
         If objCategory.CategoryType.Equals(CategoryType.Annotation) Then
              Dim objCollector As FilteredElementCollector = New FilteredElementCollector(objDocument).OfCategoryId(objCategory.Id)
              ListOfElementId.AddRange(objCollector.ToElementIds)
         End If
    Next
Return ListOfElementId
Kind Regards
David
jeremytammik
Dear David,
Congratulations on finding a solution that suits your needs and thank you for sharing it with us.
I cannot comment on whether the filtering criteria can be improved.
You can optimise it slightly by returning the `ICollection` of element ids generated by the call to `ToElementIds`.
There is probably no need nor any advantage in using that to create yet another own `List` of element ids.
Every new list or other collection creation requires a new memory allocation and copying across of the existing data, cf. FindElement and Collector Optimisation, especially item 3:
http://thebuildingcoder.typepad.com/blog/2012/09/findelement-and-collector-optimisation.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
perry.swoboda
Just so that people not despair for easily querying all tags, the original poster's code works in Revit 2020.
Here is my version tweaked to only return Material Tags. (in C#)
var collector = new FilteredElementCollector(doc).OfClass(typeof(IndependentTag)).Cast<IndependentTag>().Where<IndependentTag>(tag => tag.IsMaterialTag == true);
jeremytammik
Thank you for sharing this. I added it to The Building Coder samples for future reference:
https://github.com/jeremytammik/the_building_coder_samples/compare/2020.0.147.16...2020.0.147.17
    /// <summary>
    /// Return all tags, optionally
    /// material tags only
    /// </summary>
    IEnumerable<IndependentTag> GetMaterialTags(
      Document doc,
      bool material_only )
      IEnumerable<IndependentTag> tags
        = new FilteredElementCollector( doc )
          .OfClass( typeof( IndependentTag ) )
          .Cast<IndependentTag>();
      return material_only
        ? tags
        : tags.Where<IndependentTag>(
          tag => tag.IsMaterialTag );
Jeremy Tammik
The Building Coder
