Mechanical Settings - Hidden Line Setting
david_rock
david_rock
Is the Mechanical Hidden Line Setting available via the api?
I need to know as I am writing a line style purge command.
Kind regards
David
jeremytammik
Dear David,
For pipe or duct or what?
I see this UI description to specify hidden line settings for pipe:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
I'll check with the development team for you, but it would help to be more specific.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
The development team replied:
We have DuctSettings and PipeSettings classes, as well as settings, but I don't see this option on any of them.
Sorry about that.
If this is important to you, please submit a wish list item in the Revit Idea Station and ensure it gets lots of votes.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
david_rock
Thank you very much for making the enquiry.
I will add it as a wish list to the Revit Idea Station.
Kind regards
David
