For Information: Revit 2021.1.2 Hot-Fix and InstallLocation
matthew_taylor
Advisor Advisor
matthew_taylor
Hello all,
Just passing on some relevant information.
Upon installing the Revit 2021.1.2 hot-fix the InstallLocation registry property no longer reports the correct value.
Our installation location bible reference from @jeremytammik shows us where to look in the registry for the installation location of Revit: https://thebuildingcoder.typepad.com/blog/2013/04/perpetual-guid-algorithm-and-revit-2014-product-gu...
This information is still accurate, but some of the information that we may go there for is no longer valid.
At this location:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7346B4A0-2100-0510-0000-705C0D862004}
Our value for InstallLocation is now:
Revit 2021\
instead of a fully qualified path such as:
C:\Program Files\Autodesk\Revit 2021\
I believe someone from our organisation is reporting this issue, but I would suggest creating your own support call with Autodesk if this change affects you.
I hope this saves someone out there a bit of time.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
m_dijkman
We encountered this problem with installing RhinoInside for Revit 2021.
it can't install it because of this InstallLocation
jeremy_tammik
Dear Matt,
Thank you very much for pointing this out. I am asking the development team whether this is intentional.
Cheers,
Jeremy
jeremy_tammik
The development team responded that this is a known issue and resolved in Revit 2022. I hope this helps.
matthew_taylor
Thanks @jeremy_tammik!
Yes, I noticed it was no longer an issue in 2022. 🙂
Hope things are well with you.
Cheers,
-Matt
