Finding the railing host
Hello!
On my Revit project, I need to analise lots of stairs.
But, using the Revit LookUp, when I select one railing, I can`t identify the stair that is the host of this railing.
Or, on the other way, when I select one stair, I can`t identify the railings that are connected with that stair.
What can I do to recognize these on my code?
Thanks!
constantin.stroescu
I am not sure that my method could suit you. I don't use Revit LookUp.
I use Railing Tags based on Mark not on Type Mark and the control is made using Railing Schedule:
  1. first I tag all the railings , but I apply a new family tag based on Label Mark instead of Type Mark so that each railing has its own name - Image 01
  2. then I make a Railing Schedule that Contains the field Mark - Image 02
  3. In schedule , selecting a line from the table will highlight the railing on model...so , I can have control where the railing is placed in a View...
Image 01
Image 02
Constantin Stroescu
Joe.Ye
Hello, Railing.HostId() method returns the stair, the host of the railing. Note: Not all the methods and properties are shown in the RevitLookup. For full methods and properties, please refer to the RevitAPI.chm file in the Revit SDK.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
