How to get the parameter value of LookUpCommandId(string name)?
Message 1 of 8
I try many times,but the LookUpCommandId(string name) just return null.
Replies (7)
Message 2 of 8
PhillipM
Try something like this
app.PostCommand(Autodesk.Revit.UI.RevitCommandId.LookupPostableCommandId(Autodesk.Revit.UI.PostableCommand.Whatever here.....))
Cheers
Phillip
Message 3 of 8
Joe.Ye
Hello, Which command do you want to get its command id?
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Message 4 of 8
Thanks!
but I lookup the Command ,which added by Add-In method
Message 5 of 8
The Command added by Add-in method.
I want to get the current RibbonButton's name when clicked it!
Message 6 of 8
Did you try using the ClientId as name ? Something like this :
// External commands defined by add-ins are
  // identified by the client id specified in
  // the add-in manifest
  string name
    = "64b3d907-37cf-4cab-8bbc-3de9b66a3efa";
  RevitCommandId id_addin
    = RevitCommandId.LookupCommandId(
      name );
Please refer to this blog post of my colleague Jeremy :
http://thebuildingcoder.typepad.com/blog/2013/10/programmatic-custom-add-in-external-command-launch....
Hope this helps.
Partha
Message 7 of 8
Thanks very much!
Message 8 of 8
paolomod3nese
Just a heads up for anyone: if you're trying to get a command defined in a custom button, the answer also on the same post outlined by Partha (https://thebuildingcoder.typepad.com/blog/2013/10/programmatic-custom-add-in-external-command-launch...)
  // External tool commands defined by add-ins are
  // identified by the string listed in the
  // journal file when the command is launched
  // manually.
  string name_addin_button_cmd
    = "CustomCtrl_%CustomCtrl_%"
      + "Add-Ins%Post Add-in Command%Dummy2";
  RevitCommandId id_addin_button_cmd
      name_addin_button_cmd );
  uiapp.PostCommand( id_addin_button_cmd );
