Find the walls which are intersecting or not going till the bottom of beam
Message 1 of 12
I want to find that walls which is intersecting or not going till the bottom of the beam. How can I find that?
Replies (11)
Message 2 of 12
Mustafa.Salaheldin
Please provide a sample RVT file.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 3 of 12
I want to create addin for this.
Message 4 of 12
Mustafa.Salaheldin
OK I need a sample Revit project (RVT) to test on it.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 5 of 12
.Rvt File
Message 6 of 12
Charles.Piro
you can use this for start :
[Transaction(TransactionMode.Manual)]
    public class ResaAuto : IExternalCommand
        public struct InterBeamWall
            public FamilyInstance beam;
            public Wall wall;
        private List<InterBeamWall> lstInterBeamWall;
        public List<InterBeamWall> _lstInterBeamWall
            get
                return lstInterBeamWall;
        public Result Execute(ExternalCommandData extCmdData, ref string msg, ElementSet elmntSet)
            UIApplication uiapp = extCmdData.Application;
            UIDocument uiDoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uiDoc.Document;
            FilteredElementCollector FltCollwall = new FilteredElementCollector(doc).WhereElementIsNotElementType().OfCategory(BuiltInCategory.OST_Walls);
            foreach (Element elmntWall in FltCollwall)
                try
                    BoundingBoxXYZ bbXYZ = elmntWall.get_BoundingBox(doc.ActiveView);
                    Outline outlineWall = new Outline(bbXYZ.Min, bbXYZ.Max);
                    BoundingBoxIntersectsFilter intersectsFilter = new BoundingBoxIntersectsFilter(outlineWall);
                    FilteredElementCollector fltCollBeam = new FilteredElementCollector(doc);
                    fltCollBeam.WhereElementIsNotElementType().OfCategory(BuiltInCategory.OST_StructuralFraming).WherePasses(intersectsFilter);
                    foreach (Element _beam in fltCollBeam)
                        try
                            FamilyInstance beam = _beam as FamilyInstance;
                            if (beam != null)
                                InterBeamWall intersection;
                                intersection.beam = beam;
                                intersection.wall = elmntWall as Wall;
                                lstInterBeamWall.Add(intersection);
                            else
                                continue;
                        catch (Exception)
                            continue;
                catch (Exception)
                    continue;
            return Result.Succeeded;
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 7 of 12
Mustafa.Salaheldin
What is the Class of "InterBeamWall"??? What version of API??
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 8 of 12
Mustafa.Salaheldin
Pleas try this code and tell me if it works the way you want
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                FilteredElementCollector WallCollector = new FilteredElementCollector(CachedDoc);
                WallCollector.OfClass(typeof(Wall)).WhereElementIsNotElementType();
                List<Wall> walls = WallCollector.Cast<Wall>().ToList();
                StringBuilder sb = new StringBuilder();
                foreach (Element wall in walls)
                    GeometryElement geomElement = wall.get_Geometry(new Options());
                    Solid solid = null;
                    foreach (GeometryObject geomObj in geomElement)
                        solid = geomObj as Solid;
                        if (solid != null)
                            FilteredElementCollector BeamCollector = new FilteredElementCollector(CachedDoc);
                            BeamCollector.OfCategory(BuiltInCategory.OST_StructuralFraming).WhereElementIsNotElementType();
                            BeamCollector.WherePasses(new ElementIntersectsSolidFilter(solid)); // Apply intersection filter to find matches
                            List<Element> beams = BeamCollector.Cast<Element>().ToList();
                            if (beams.Count > 0)
                                foreach (Element beam in beams)
                                    sb.AppendLine(string.Format("Wall: {0} with Id: {1} intersects with Beam: {2} with Id: {3}", wall.Name, wall.Id.ToString(), beam.Name, beam.Id.ToString()));
                            break;
                TaskDialog.Show("Revit", sb.ToString());
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
Please don't forget to mark this reply as an answer if it satisfies your needs.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 9 of 12
Charles.Piro
Hi mustafa,
it's not a Class. It's an object "Struct" : Microsoft
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 10 of 12
Mustafa.Salaheldin
Ok I didn't notice that you have defined the Struct in the top of the code because my mouse scroll down accidentally Smiley Very Happy
Nice Work anyway. Smiley LOL
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 11 of 12
Charles.Piro
Ah ok !! : Smileyvery-happy:
Thanks, nice work too!
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 12 of 12
jeremytammik
The Revit API provides the ReferenceIntersector class to search for element intersections:
http://www.revitapidocs.com/2017/36f82b40-1065-2305-e260-18fc618e756f.htm
Here is a full explanation of using it:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2018/ENU/Revit-API/files/GUID-...
Here is a full-fledged example using the ReferenceIntersector to determine a point on a neighbouring, parallel wall to create dimensioning:
http://thebuildingcoder.typepad.com/blog/2011/02/dimension-walls-using-findreferencesbydirection.htm...
It uses the ReferenceIntersector class to determine a point on a neighbouring, parallel wall to create dimensioning.
At that time, the method was called FindReferencesByDirection. It was later wrapped in the ReferenceIntersector class. The external command CmdDimensionWallsFindRefs demonstrating its use has been updated to use the new class and is available in The Building Coder samples on GitHub:
https://github.com/jeremytammik/the_building_coder_samples
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
