How to Assign line pattern to model line
I was able to create my linePattern. I can create the model line. I can assign a color to the line. How do I assign my LinePatternElement to my model line so it shows up dashed?
public void createGraphicsStyle()
			Autodesk.Revit.DB.Document doc = this.ActiveUIDocument.Document;
			 //create an arc first
			 XYZ end0 = new Autodesk.Revit.DB.XYZ(0, 1, 0);
                XYZ end1 = new Autodesk.Revit.DB.XYZ(0, 2, 0);
                XYZ pointOnArc = new XYZ(.2,.5,0);
                 Transaction trans = new Transaction(doc,"create model arc");
                trans.Start();
                //try to get existing line style
                string nameOfCategory = "AuditoriumMaker Row Layout Lines";
                string nameOfLinePattern = "AuditoriumMaker Row Layout Line Pattern";
                Color auditoriumMakerRowLayoutLineColor = new Color(238, 132, 63);
                Category myCategory = doc.Settings.Categories.get_Item(BuiltInCategory.OST_Lines);
                if(myCategory.SubCategories != null)
                	foreach (var element in myCategory.SubCategories)
                		Category cat = element as Category;
                		if(cat.Name == nameOfCategory)
                			trans.Commit();
                			return;
                //Make the custom line pattern
                LinePattern myLinePattern = new LinePattern(nameOfLinePattern);
                IList<LinePatternSegment> rowLayoutLinePatternSegmentList = new List<LinePatternSegment>();
                LinePatternSegment lineSeg1 = new LinePatternSegment(LinePatternSegmentType.Dash, .010);
                LinePatternSegment lineSeg2 = new LinePatternSegment(LinePatternSegmentType.Space, .010);
                rowLayoutLinePatternSegmentList.Add(lineSeg1);
                rowLayoutLinePatternSegmentList.Add(lineSeg2);
                myLinePattern.SetSegments(rowLayoutLinePatternSegmentList);
                LinePatternElement myNewLinePatternElement = LinePatternElement.Create(doc, myLinePattern);
                //assign the line pattern to the element
                myNewLinePatternElement.SetLinePattern(myLinePattern);
                //create line style
                Category parentCategory = doc.Settings.Categories.get_Item(BuiltInCategory.OST_Lines);
                myCategory = doc.Settings.Categories.NewSubcategory(parentCategory, nameOfCategory);
                myCategory.LineColor = auditoriumMakerRowLayoutLineColor;
                //myCategory.LinePatternElement??????????
                Plane myPlane = new Plane(new XYZ(0,0,1), new XYZ(0,0,0));
                SketchPlane mySketchPlane = SketchPlane.Create(doc, myPlane);
                Arc arc = Arc.Create(end0, end1, pointOnArc);
                ModelArc modelArc = doc.Create.NewModelCurve(arc, mySketchPlane) as ModelArc;
                //assign the LineStyle to the modelArc
                GraphicsStyle gs = myCategory.GetGraphicsStyle(GraphicsStyleType.Projection);
                modelArc.LineStyle = gs;
                trans.Commit();
Revitalizer
in Revit 2017, you can use Category.SetLinePatternId:
http://forums.autodesk.com/t5/revit-api/how-to-set-line-pattern-in-line-style/td-p/3731078
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
JimJia
Yes, Category.SetLinePatternId is the solution, however, prior to 2017, Revit doesn't support LinePattern modification for category yet.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
