Filtering Walls by Name and Base Constraint
I'm having difficulty trying to filter out my walls by a specific name (which works) and by the walls' base constraint to equal the associated level of my active view. This is the code I currently have. The Build is successful but doesn't do anything when I execute the macro. I believe the issue is within the reading the string. Thank you in advance for the help.
Document doc = this.Application.ActiveUIDocument.Document;
            View myActiveView = doc.ActiveView;
            Parameter level = myActiveView.LookupParameter("Associated Level");
            String levelName = level.AsString();
FilteredElementCollector swwallfilter = new FilteredElementCollector(doc, myActiveView.Id);
                List<Element>swwalls = swwallfilter.OfCategory(BuiltInCategory.OST_Walls).ToList();
                    var swtypeelements = from element in swwallfilter
                    where element.Name.Contains("Shear Wall") &&
                        element.get_Parameter(BuiltInParameter.WALL_BASE_CONSTRAINT).Equals(levelName)
                        select element;
I guess this doesn't go by name (string) but rather the level you are looking for.
should work by Id.
Please correct me if I am wrong, didn't try.
Christian
FAIR59
element.get_Parameter(BuiltInParameter.WALL_BASE_CONSTRAINT) is a Parameter
so try
element.get_Parameter(BuiltInParameter.WALL_BASE_CONSTRAINT).asValueString().Equals(levelName);
Thank you! That worked. I knew it was something with the string.
r_b_1366
List<Wall> wallCollector = new List<Wall>();
string level= form1.Mylevel;
ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Walls);
FilteredElementCollector collector = new FilteredElementCollector(doc);
IList<Element> walls = collector.WherePasses(filter).WhereElementIsNotElementType().ToElements();
foreach (Element e in walls)
string basconstraint = e.get_Parameter(BuiltInParameter.WALL_BASE_CONSTRAINT).AsValueString();
if (basconstraint == level)
wallCollector.Add(e as Wall);
I think this is also useful for the Filtering Walls by Base Constraint
