filtered collection to selection
Can someone give me an example of passing a filtered collection to a selection. I have clear examples of each, bit I'm having trouble sorting out how to combine them. Thanks.
BKSpurgeon
I myself am a noob, but please post the individual examples, then maybe I can help?
ollikat
Hi
Do you mean how to get elements from the FilteredElementCollector to the active selection? That shouldn't be too complicated.
We have the following extension method for the Selection class:
public static void SetSelection(this Selection sel, IEnumerable<ElementId> ids)
  if (sel == null)
    throw new ArgumentNullException("sel");
   if (ids == null)
    throw new ArgumentNullException("ids");
  sel.SetElementIds(ids.ToList<ElementId>());
Where "Selection" is from Autodesk.Revit.UI.Selection namespace. The enumerable can be retreived using for example
FilteredElementCollector.ToElementIds().
Ah...almost forget to mention that the ToList<T>() method is a Linq extension method for the IEnumerable System.Linq namspace.
Hope this helps.
Autodesk.Revit.UI.Selection.SelElementSet
selElements = uiDoc.Selection.Elements;
loop all items in filter
foreach
selElements.Insert( items);
uiDoc.Selection.Elements = selElements;
Thanks & Regards
Sanjay Pandey
BKSpurgeon
Hi i don't understand your question even:
Perhaps this might help:
it filters a selection and places it in a collection (the reverse of what you are trying to do).......but you may still find it helpful:
http://through-the-interface.typepad.com/through_the_interface/2008/05/finding-all-the.html
