Revit Wall Cut Pattern visibility
Message 1 of 1
I'm trying to turn off the wall cut pattern visibility using the API.
Category val1 = rvtUIDoc.Document.Settings.Categories.get_Item BuiltInCategory.OST_Walls);
Autodesk.Revit.DB.CategoryNameMapcat1 = val1.SubCategories;
foreach (Category cat2 incat1)
if (cat2.Name == "cut Pattern")
cat2.set_Visible(rvtUIDoc.Document.ActiveView,
false);
The above code is what I've tried so far. Does not work.
Replies (0)
