Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Filter according to shared parameter
5 REPLIES 5
lrsmns
245 Views, 5 Replies
I'm trying to collect family symbols that contain a specific value from a shared parameter...
Typically I would collect them according to a specific BuiltInCategory, but since there are multiple categories within the collection, I would first get the Elements, use the LookupParameter method, and cast it to FamilySymbols; but now with this approach its not working.
Would appreciate any insights! Thank you!
public ObservableCollection<RevitFamilyWrapper> CollectObjects(string ParameterValue)
    var familySymbols = new FilteredElementCollector(doc)
            .OfClass(typeof(Element))
            .Where(x => x.LookupParameter("ParameterName").HasValue &&
            x.LookupParameter("ParameterName").AsString().Equals(ParameterValue))
            .Cast<FamilySymbol>()
            .Select(x => new RevitFamilyWrapper(x));
    return new ObservableCollection<RevitFamilyWrapper>(familySymbols);
5 REPLIES 5
jeremy_tammik
in reply to: lrsmns
You can filter for several categories at the same time by combining several category filters with a logical OR filter:
The most efficient way to filter for specific parameter values is to use a parameter filter:
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
Mohamed_Arshad
in reply to: lrsmns
HI @lrsmns
    FamilySymbol is the base class for all family Categories. So you can apply for multiple category, and don't need to filter using Element, we can directly use the FamilySymbol in our filter. Kindly check the below updated code.
Reference Code
 public ObservableCollection<RevitFamilyWrapper> CollectObjects(string ParameterValue, Document doc)
            var familySymbol = new FilteredElementCollector(doc).OfClass(typeof(FamilySymbol))
                .Select(x => new RevitFamilyWrapper(x as FamilySymbol));
            return new ObservableCollection<RevitFamilyWrapper>(familySymbol);
Hope this will Helps 🙂
Thanks & Regards,
Mohamed Arshad K
lrsmns
in reply to: Mohamed_Arshad
I have tried that approach, however it returned null within the LookupParameter method...
I assumed that since LookupParameter method lies under the Element class method, it needs to collect as Element type first. However, as i showed in the code above, it still doesnt work.
Mohamed_Arshad
in reply to: lrsmns
HI @lrsmns
    Null is returned because a few family symbols do not has the parameter loaded. So it is returned null. You can add the condition to check the null as well.
    The lookup Parameter method will work for all Class because it from the base Class Element. So we don't need to worry about that
                .Where(x =>
                x.LookupParameter("ParameterName") != null &&  //NUll Checking
                x.LookupParameter("ParameterName").HasValue && //Empty Checking
                x.LookupParameter("ParameterName").AsString().Equals(ParameterValue)) //Exact Value Checking
Have you tried above method ?
Thanks & Regards,
Mohamed Arshad K
lrsmns
Ahaa got it! Thank you so much for the helfpul hint
Forma Design Contest
Rail Community
