Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Family with configurable connectors
1 REPLY 1
256 Views, 1 Reply
In our application we have different air terminal families, some of them have same geometry but the connector type is different and we had to create different families for each connector type.
Is it possible to change connector properties via parameters ( ex. associate  family parameter with System Classification or Flow Direction/Configuration ) or to have two connects and hide one of them depending on the selected type?
I now that this was not possible before ( Revit 2014, 2015, 2016 ), but maybe it is possible from Revit 2017 or 2018?
If it is not possible then do you know if this will be added in the future, I mean is it on the Revit wish list?
1 REPLY 1
Actually this is a family connector question but we are also interested in any other way, via the API, of setting connector properties without editing the family.
Rail Community
