Is it possible to update Revit view without submitting windows form?
I have a listview inside of a windows form that I have created through visual studio for my add-in. I am currently able to highlight elements in my Revit file based on what items have been selected in the listview but only o. I am wondering is it possible to have an event (or any method really) which automatically highlights an element based on the corresponding selected listview item with the form still open (that is without having to submit the form)?
Cheers,
Filip Karisik.
jeremytammik
Yes.
You can implement an external event.
Trigger it from your modeless form.
In the event handler, use the Selection class:
http://www.revitapidocs.com/2017/31b73d46-7d67-5dbb-4dad-80aa597c9afc.htm
Its SetElementIds method defines and highlights the current selection:
http://www.revitapidocs.com/2017/cf8c11bb-f0c7-6d50-cbdf-41d0a010d9d6.htm
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
I probably should have designed my code with that in mind from the beginning.
Thanks Jeremy. You've been a great help throughout.
jeremytammik
My pleasure entirely.
Thank you for your appreciation!
Good luck with all your add-ins and all your other endeavours!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
