Failed to save document - Revit 2015
MartinLucansky3580
MartinLucansky3580
Hello, what is this bloody message means ?
Revit is unable to save document, it refuses it...
my RAM is OK, empty from 70 %  of 16 GB
my TEMP directory is cleaned
Directory where i have projects has  "read-only" attributions (full blue square filled) --- but till today it has not been problem with that (maybe windows it had changed now for some reasons )
This problem is in any of models, (even in Revit 2014 models) so it depends on some windows settings ???
I cannot work now, because i cannot save the models.
does have somebody experience with thiss ?
Thank You
rosalesduquej
Dear Martin,
Are you trying to save your file from the Revit API issue, or from the Revit UI ?
Please note that this forum is dedicated to Revit API development questions only.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try the Revit product support discussion forum instead for that.
You can find more information about the non-API forums we have for Revit.
http://forums.autodesk.com/t5/revit-api/this-forum-is-for-revit-api-programming-questions-not-for/td...
Hope this helps you out.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
