EXPORT Specific Walls to individual layers
I have a client who uses autocad and would like the structural shear walls (comes from a linked model) on a seperate layer (IE "A-STRUCT") is there a way to set up a filter or a modifier to do that?
Chris
jeremytammik
Dear Chris,
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically, or just using the standard Revit user interface?
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try the Revit product support discussion forum instead for that.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks Jeremey -
"REVIT 2015" wasn't an option to post to (I assumed the MEP, ARCH, etc forums were for previous releases) so I took a shot that this was the correct forum to post in.
rosalesduquej
Hi Chris,
You can find more information about the non-API forums we have for Revit.
http://forums.autodesk.com/t5/revit-api/this-forum-is-for-revit-api-programming-questions-not-for/td...
Hope this helps you out.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
