Message 1 of 1
Failed to insert tee(from converting lines into pipes)
- Mute
- Permalink
- Report
Estoy usando este metodo,donde a partir de tres linea,que converge en un punto,crea tuberias,pero no me deja inserta un tee,a pesar de que los puntos de origen de las tuberias coincinden(Estos es una prueba).Que me estoy perdiendo?
I am using this method, where from three lines, which converge at a point, creates pipes, but it does not let me insert a tee, even though the points of origin of the pipes coincide (This is a test).
What am I missing?
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
var elementList = GetPipeLine(uidoc);
CreatePipe(uidoc, elementList);
return Result.Succeeded;
/// <summary>
/// An interface that provides the ability to filter objects during a selection operation
/// Una interfaz que proporciona la capacidad de filtrar objetos durante una operación de selección.
/// </summary>
public class PlanarFaceSelectionFilter : ISelectionFilter
Document _doc;
public PlanarFaceSelectionFilter(Document doc)
_doc = doc;
public bool AllowElement(Element elem)
return true;
public bool AllowReference(Reference reference, XYZ position)
if (_doc.GetElement(reference).GetGeometryObjectFromReference(reference) is PlanarFace)
return true;
return false;
#region Obtener una lista de tuberia
/// <summary>
/// Obtener una lista de tuberia
/// </summary>
/// <param name="uidoc"></param>
/// <returns></returns>
public List<Element> GetPipeLine(UIDocument uidoc)
ISelectionFilter selectionFilter = new PlanarFaceSelectionFilter(doc);
IList<Reference> refer = uidoc.Selection.PickObjects(ObjectType.Element, selectionFilter, "Select mulitple planar faces");
List<Element> elementlist = new List<Element>();
foreach (Reference reference in refer)
Element elem = doc.GetElement(reference);
elementlist.Add(elem);
return elementlist;
#endregion
#region Creacion de tuberia y la Tee
/// <summary>
/// Creacion de Tuberia
/// </summary>
/// <param name="elementlist"></param>
public void CreatePipe(UIDocument uidoc, List<Element> elementlist)
//Get PipeType
PipeType pipeType = new FilteredElementCollector(doc).OfClass(typeof(PipeType)).FirstElement() as PipeType;
//Get Level
Level level = new FilteredElementCollector(doc).OfClass(typeof(Level)).First() as Level;
//Get SystemPipe
FilteredElementCollector syscollector = new FilteredElementCollector(doc)
.OfClass(typeof(PipingSystemType));
ElementId pipeSysType = syscollector.FirstElementId();
Pipe newpipe;
XYZ start = null;
XYZ end = null;
//Geometry Elements
List<GeometryElement> geometrylist = new List<GeometryElement>();
foreach (Element element in elementlist)
GeometryElement geometryElement = element.get_Geometry(new Options());
geometrylist.Add(geometryElement);
using (Transaction tx = new Transaction(doc, "create pipe"))
try
tx.Start();
List<Line> lines = new List<Line>();
List<Pipe> pipeList = new List<Pipe>();
foreach (GeometryElement geoElem in geometrylist)
foreach (GeometryObject geoObj in geoElem)
Line line = geoObj as Line;
lines.Add(line);
start = line.GetEndPoint(0);
end = line.GetEndPoint(1);
if (pipeType != null)
newpipe = Pipe.Create(doc, pipeSysType, pipeType.Id, level.Id, start, end);
pipeList.Add(newpipe);
Element element = doc.GetElement(newpipe.Id);
Parameter parameter = element.get_Parameter(BuiltInParameter.RBS_PIPE_DIAMETER_PARAM);
parameter.Set(10 * 0.00733);
//fitting Tee
ElementType teeType = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PipeFitting)
.OfClass(typeof(ElementType))
.Cast<ElementType>()
.Where(x => x.FamilyName.Contains("Tee")).FirstOrDefault();
// Get FamilySymbol for Tap I want to use.
//FamilySymbol teeType = null;
//doc.LoadFamilySymbol(@"D:\M_Tee - PVC - Sch 40.rfa",
// "MyTee", out teeType);
//// Symbol needs to be activated before use.
//if (!teeType.IsActive && teeType != null)
// teeType.Activate();
// doc.Regenerate();
RoutingPreferenceManager preferenceManager = newpipe.PipeType.RoutingPreferenceManager;
preferenceManager.AddRule(RoutingPreferenceRuleGroupType.Junctions, new RoutingPreferenceRule(teeType.Id, "MyTee"));
int routingPreferenceGroupCnt = preferenceManager.GetNumberOfRules(RoutingPreferenceRuleGroupType.Junctions);
if (routingPreferenceGroupCnt > 1)
for (int i = 0; i != routingPreferenceGroupCnt; i++)
preferenceManager.RemoveRule(RoutingPreferenceRuleGroupType.Junctions, 0);
doc.Regenerate();
for (int i = 0; i < pipeList.Count - 1; i++)
ConnectorManager pipe_conectorManager1 = pipeList[i].ConnectorManager;
ConnectorSet pipe_connectorSet1 = pipe_conectorManager1.Connectors;
ConnectorManager pipe_conectorManager2 = pipeList[i + 1].ConnectorManager;
ConnectorSet pipe_connectorSet2 = pipe_conectorManager2.Connectors;
ConnectorManager pipe_conectorManager3 = pipeList[i + 2].ConnectorManager;
ConnectorSet pipe_connectorSet3 = pipe_conectorManager3.Connectors;
Connector pipe_connector1 = null;
Connector pipe_connector2 = null;
Connector pipe_connector3 = null;
foreach (Connector connector1 in pipe_connectorSet1)
if (connector1.Id == 0)
continue;
foreach (Connector connector2 in pipe_connectorSet2)
double minDist = double.MaxValue;
var punto2 = connector2.Origin;//{(55.838062275, -11.848221885, 0.000000000)}
double d = connector1.Origin.DistanceTo(connector2.Origin);
if (d < minDist)
pipe_connector1 = connector1;//{(55.838062275, -11.848221885, 0.000000000)}
pipe_connector2 = connector2;//{(55.838062275, -11.848221885, 0.000000000)}
minDist = d;
continue;
foreach (Connector connector3 in pipe_connectorSet3)
if (connector3.Id == 1)
continue;
double d = connector1.Origin.DistanceTo(connector3.Origin);
if (d < minDist)
pipe_connector3 = connector3;
minDist = d;
//foreach (Connector connector2 in pipe_connectorSet2)
// if (connector2.Id == 0)
// continue;
// foreach (Connector connector3 in pipe_connectorSet3)
// if (connector3.Id == 1)
// continue;
// double minDist = double.MaxValue;
// double d = connector2.Origin.DistanceTo(connector3.Origin);
// if (d < minDist)
// pipe_connector2 = connector2;
// pipe_connector3 = connector3;
// minDist = d;
var p1 = pipe_connector1.Origin;//{(55.838062275, -41.375780940, 0.000000000)}
var p2 = pipe_connector2.Origin;//{(55.838062275, -41.375780940, 0.000000000)}
var p3 = pipe_connector3.Origin;//{(55.838062275, -41.375780940, 0.000000000)}
//doc.Create.NewTeeFitting(pipe_connector1, pipe_connector2, pipe_connector3);
//doc.Create.NewTeeFitting(pipe_connector1, pipe_connector3, pipe_connector2);
//doc.Create.NewTeeFitting(pipe_connector2, pipe_connector1, pipe_connector3);
//doc.Create.NewTeeFitting(pipe_connector2, pipe_connector3, pipe_connector1);
//doc.Create.NewTeeFitting(pipe_connector3, pipe_connector2, pipe_connector1);
doc.Create.NewTeeFitting(pipe_connector3, pipe_connector1, pipe_connector2);
foreach (Element elem in elementlist)
doc.Delete(elem.Id);
tx.Commit();
catch (Exception ex)
TaskDialog.Show("Info", "Error " + ex.Message);
tx.RollBack();
#endregion
