failed to initialize the add in "formit conversion" because the assembly "C:\program files\autodesk\formit converterribbon.dll" does not exist
brihamandree_15
brihamandree_15
Community Visitor
Community Visitor
moturi.magati.george
Hi @brihamandree_15,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
  Moturi George,     Developer Advocacy and Support,  ADN Open
